Bizhub 808, C759 black drum counter
  • mjmjross
    • Apr 2019
    • 11
    Hey all,
    Last week I replaced the black drum on an 808 and after gradation, the counter didn't reset. It showed "Stabilizing" once I closed the door (like normal) but never went back to 100%. I wrote it off to "whatever". Then yesterday I replaced the black drum on a C759 and ran into the same thing. Both were replaced because of imaging issues. Now I'm thinking it's something I might be missing.
    Anyone else?
    Ideas?
    Thanks!
  • copier tech
    • 8202
    Re: Bizhub 808, C759 black drum counter
    Originally posted by mjmjross
    Hey all,
    Anyone else?
    Ideas?
    Thanks!
    What drum are you fitting to the 759?
    & what model is an 808 ?
    • tsbservice
      Field tech
      • 8053
      bizhub 808 is from 758-808-958 family. As for not resetting life counts maybe drum has bad chip.
      Edit:
      Also check for bent pins inside machine may not read correctly new chip.
      • WLIT
        • Jan 2020
        • 40
        Also, don't forget to press Start after you have completed gradation. In Service Mode it says this in the black box right above where you hit Gradation. Easy to overlook this.
