AccurioPrint C759 washed out print
  • John-r
    • Mar 2020
    • 10
    Hi, I have a konica minolta accurioprint c759, I have a problem with the black color being a little washed out on unncoted paper from 120grs and up. Is this normal on this printer or are they possible with some sort of adjustment? The printer has only 20k print and has efi fiery, has also had the fuser temperature set up to max which helped a bit.
    Image is not much washed out but the printer is used for greetingcards and works ok as long as they do not become dark images.
    The colors are adjusted in fiery and are fine with the exception of dark colors but especially black
  • copier tech
    • 8202
    Re: AccurioPrint C759 washed out print
    Can you post a sample of the issue.?
    Genuine toner?
    • John-r
      • Mar 2020
      • 10
      Genuine toner?
      Genuine toner[emoji108]
      Sent fra min VOG-L29 via Tapatalk
      • John-r
        • Mar 2020
        • 10
        maybe not as bad as the picture shows and this is on the duplex last page which is worse than the first page
