Pro 951 vs Pro 1100
  • wjurls
    • Feb 2017
    • 498
    #16
    Re: Pro 951 vs Pro 1100
    Originally posted by allan
    Have had it where it will empty the entire dev tank in no time. Found that it was the way i was handling the dev tank that pressed against the bottom edge of tank that deformed the mylar. I only get the C2803 when the dev is slightly over life, auto gama adjustment also fails. Spiking the dev with some toner and reinitialize only works for a couple of thousand prints.
    Had that happen on a 1051 from mishandling. I managed to "reform" the bottom plate just enough to correct the dumping.
    • Lordnixon
      • Jul 2017
      • 18
      #17
      After replacing the developer, I have the error c2802. Do you think the reason is similar? Adding toner to the block solves the problem for several thousand prints. So far, I have ordered TCR, TCB, but I am not completely sure that they will help. The intermediate block is full, it works during printing, but the toner still goes away)))
      • allan
        RTFM!!
        • 5462
        #18
        Best to start a new thread.
        Whatever
