C300i , code C 9401
  • pinspin
    • Oct 2011
    • 156
    [Error Code] C300i , code C 9401
    Hello. When turned on, the lamp lights up, the scanner starts moving and the copier shows the code C 9401. We replaced Led exposure unit, CCD unit, SCDB, CPUB, Baseb,power supply, flat cable, storage and performed a firmware update. It did not help. We would be grateful for any advice! Thank.
  • tsbservice
    Field tech
    • 8076
    Re: C300i , code C 9401
    Holy c.ap! You replaced more than all required and it still won't work. Any options added, try without them.
    • Bix
      • Apr 2018
      • 1421
      Anyof the trouble codes C6102/6751/9401. Itis caused by the loose screw at the timing belt pulley.Ifthe screw was loosened, the pulley is idling which makes scanfunction faultily.Asthe result, the trouble codes related to the scan malfunction occurfrequently.
      Tightenthe screw if it is loosened.
      Ifthe screw is not loosened, it must be caused by other causes. Pleasecheck the tension of the belt or check other solutions on the servicemanual.
      • pinspin
        • Oct 2011
        • 156
        We performed all the recommendations, the problem is not solved. Thanks for the advices, we continue to diagnose)))
        • dawidos01111
          • Mar 2024
          • 2
          What is the solution to the problem?
          • allan
            RTFM!!
            • 5462
            Have you check the small timing belt on the motor for damage?
            Whatever
            • dawidos01111
              • Mar 2024
              • 2
              Yes, he's correct. I have a problem with this error on C450i. I replaced LED Exposure unit, scdb, ccd unit, cpub and baseb. FW G00-P8 and GC2-Q9. I replaced wiring between scdb and led exposure unit and ccd unit and baseb. Problem not solved.
              • occus
                • 339
                • tsbservice
                  Field tech
                  • 8076
                  I would unset and disconnect DF and try machine again.
                  • iggy
                    • Nov 2023
                    • 3
                    What is the solution to the problem? i have same problem on a c300i.
                    • Gift
                      • Mar 2011
                      • 2459
                      It's usually the timing belt or sun exposure.
                      • gere1
                        • Oct 2018
                        • 20
                        With a new machine I had the problem of (AA2JN14500 CCD Cable)
                        • iggy
                          • Nov 2023
                          • 3
                          This is how it looks like when you make a copy....i hav repl SKM_C45824091216020.jpg aced the ccd cabel and ccd board and checked scanner motor and belt.
                            • 23010
                            Originally posted by iggy
                            This is how it looks like when you make a copy....I have replaced the CCD cable and CCD board and checked scanner motor and belt.SKM_C45824091216020.jpg
                            What does a scan look like?
                            • iggy
                              • Nov 2023
                              • 3
                              When you print counter list it's ok but when you scan it gets bad.
