High Durability BK Drum DR315K
  • copier tech
    • 8103
    [Misc] High Durability BK Drum DR315K
    Apologies if this has been asked before but what are your experiences with the High Durability BK Drum DR315K, worth the extra cost vs life?
    I thought the only difference was the chip count, so the the OPC drum etc were identical.
    High Durability BK Drum DR315K.pdf
  • tech51
    • 846
    • copier tech
      • 8103
      Re: High Durability BK Drum DR315K
      • emujo2
        • Mar 2017
        • 1580
        we were told to wait for a required f/w update to use these..your post made me realize that I never saw anything later to allow usage..The cost is about the same if you compare stated yields..not sure if I want to spend almost 2x per drum only to have them crap out as well.
        • copier tech
          • 8103
          This backs up my thought in that the only difference is the chip count/life.
          • tech51
            • 846
            The first picture is the long life drum, the second one is the standard drum. You can see the charge roller cleaner is different. I believe they changed it to help prevent drum score marks.
            Any firmware from g00 v1 onwards will enable use of this drum.
            Regards. 51
            • tsbservice
              Field tech
              • 7912
              Originally posted by tech51
              [ATTACH=CONFIG]48453[/ATTACH][ATTACH=CONFIG]48454[/ATTACH]
              Regards. 51
              Yes helical charge roller cleaning rollers.
              • copier tech
                • 8103
                Regards. 51
                Thanks for the pics. Not sure how this would stop the OPC wearing out.
                • allan
                  RTFM!!
                  • 5459
                  No counter data is stored on the chip. Chip consists of a drum set resistor and a fuse that reset the count on the machine.So surely you must change something on the machine to in crease the yield info. So guess it will be firmware and soft switches. Once its done you need to replace only with the high yield drums.
                  Whatever
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    lol
                    That improved pcr cleaning setup is already on the dr314 for the 8e bk models, in comparison with the regular dr313k those long life drums just fail at half life in my experience.
                    It might make some difference but i'm skeptical as to it being worth twice the price.
                    • tech51
                      • 846
                      No dipswitches to set only firmware update required.
                      Also once firmware is updated either drum type can be used.
                      • tech51
                        • 846
                        • copier tech
                          • 8103
                          The count is kept on the drum chip? If I swap round 2 colours drums the counter moves with the drum.
                          • tsbservice
                            Field tech
                            • 7912
                            Counters stay with machine not with drums.
                              Interesting thread but has anyone determined if it's best to use the high durability drum? I need to know so I can stop reading this thread.
