Konica Minolta Bizhub c458 Printing problem
  • vikashkj
    • Feb 2021
    • 6
    [Misc] Konica Minolta Bizhub c458 Printing problem
    I Have a Konica Minolta Bizhub c458. the printer is printing files distorted. but while trying to take copy the output is fine. can anyone give a solution.
    I have attached the image also
  • Max
    • Oct 2011
    • 561
    Re: Konica Minolta Bizhub c458 Printing problem
    Mfpb board I would say.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      yep looks pretty screwed alright.
      I'd hazard a guess at one of the ram chips going bad on the mfp board.
      Do all the memory tests complete ok ?
      • copier tech
        • 8193
        I'd start by reseating all connection on the MFP board, especially the ribbon cables from the laser, then update the firmware.
        • vikashkj
          • Feb 2021
          • 6
          can i get the firmware
          • copier tech
            • 8193
            Sure, email us at this site.
            • vikashkj
              • Feb 2021
              • 6
              www.copierfiware.co.uk
              i tried firmware update and fixing the cables
              still the same
              what to do next?
              • tsbservice
                Field tech
                • 8031
                what to do next?
                This?
                • vikashkj
                  • Feb 2021
                  • 6
                  This?
                  Memory test are fine
                  • vikashkj
                    • Feb 2021
                    • 6
                    Mfpb board Also changed still facing the same problem
                    • REGSIS
                      • May 2016
                      • 435
                      PH unit or PH unit control board. Try to reseat 2 flat cables on the board first.
