C754e - access job log with error code C-3102
  • eunos
    • Mar 2015
    • 9
    Hi folks,
    We have a C754e which is pending retirement. Service contract has expired. Before it goes I need to connect to it using PageScope Data Administrator to retrieve the account tracking code log.
    However, the machine has a C-3102 error on the screen, and seemingly due to that I cannot connect to it using PageScope Data Administrator, that gives me the following errors in the log:
    E 3/8/2021 10:24:52 AM IP ADDRESS REDACTED KONICA MINOLTA bizhub C754e Failure:Import Registered Application List
    I 3/8/2021 10:24:52 AM IP ADDRESS REDACTED KONICA MINOLTA bizhub C754e Success:Get the OpenAPI error message(GeneralDuringFatal)
    I 3/8/2021 10:24:52 AM IP ADDRESS REDACTED KONICA MINOLTA bizhub C754e Success:Log out of a device
    So - I'm wondering if there's a way to suppress the error code to allow log-in and remote access?
    If not - if we remove the HDD can we plug it into a caddy and extract the job log from that? How is the HDD formatted and where would i find the data?
    Many thanks!
  • Synthohol
    Certified Konica Expert
    • 5808
    Re: C754e - access job log with error code C-3102
    can you just reset the error and try again?
    or check this...
    3.8.2 C3102
    (1) Contents
    Trouble type Heating roller assy failure to turn
    Trouble code C3102
    Rank A
    Detection timing During any state other than printing operation , the hard latch signal from one or both of the heating roller
    rotation latch detection 1 and the heating roller rotation latch detection 2 is turned ON.
    Trouble isolation -
    Relevant electrical parts • Heating roller rotation sensor (PS56)
    • Fusing motor (M30)
    • Printer control board (PRCB)
    • Fusing unit
    (2) Procedure
    Step Action Control signal Location of electrical components
    1 Check the fusing unit for proper installation and correct
    as necessary.
    2 Check the connector between M30-PRCB CN30 for
    proper connection and correct as necessary.
    3 Check the connector of M30 for proper drive coupling
    4 PS56 I/O check, sensor check - -
    5 M30 operation check PRCB CN30-4 (REM)
    PRCB CN30-7 (LOCK)
    4-K
    6 PRCB ICP15 conduction check
    7 Replace M30 - -
    8 Replace the fusing unit - -
    9 Replace PRCB - -
    • Link to the wiring diagram (N.1. bizhub C754/C654)
    • Link to the layout drawings for related parts by each trouble code (S.67. C3102)
    • allan
      RTFM!!
      • 5462
      Wonder if its a permanent error if resetting in and leaving the side door open would help?
      Whatever
