C250i error c6756
  • barber782
    • Aug 2011
    • 285
    C250i error c6756
    Hi everyone,
    We've had 3 customers with new c250i machines and after a week they throw a c6756 error relating to the ccdb.
    I have the latest firmware installed.
    Checked the cabling between the ccdb and scdb and all looks fine. Error will clear after reboot but will come back next day.
    Either we've got a dodgy batch or something silly.
    Please let me know if anyone has encountered this?
    Sent from my VTR-L09 using Tapatalk
  • Bix
    • Apr 2018
    • 1421
    Re: C250i error c6756
    Hi, advice. You try to write in the same thread. This is the third one you create on the same topic and it could cause confusion for those looking for your problem in the future.
    Three cases are very concerning. This is an obvious sign of a faulty production batch. When did you buy these C250i?
    • barber782
      • Aug 2011
      • 285
      Had a Forth one that had this error code. Most have been fixed by replacing the ccd board or data cable.
      • bazylius
        • Jun 2021
        • 2
        There was CCD upgrade. New firmware GC2-G4 eliminates problem.
        GoodLuck
        • avecosat
          • Jun 2012
          • 305
          GoodLuck
          Also G00-G7 for IT6
          • tmmdmmm
            • Apr 2021
            • 173
            Originally posted by barber782
            Hi everyone,
            Had a bulletin late last month regarding manufacturer changes.
            "Please be advised that all new and replacement CCD and CIS units will be supplied by a new manufacturer going forward.In order to use the units, it may be necessary to update the firmware version; otherwise a C-6756 could occur"
            For C250i, load G00-G4 or later if you purchase a replacement going forward. For original CCD, use GC2-G4
            • suomi
              • 152
              1. Details of Symptom:
              Trouble Code C-6756 occurs on the machine with new CCD unit when recovering from low power mode or sleep mode.
              For information about new CCD unit, please refer to RFKM_BT2111556EN
              2. Example of Reproduction
              ~Reproduction Environment~
              Model/FW:C360i/G00-G4
              -Procedure-
              1. Press the power key to enter sleep mode or low power mode
              2. Touch the panel to recover the machine from sleep mode or low power mode
              -Result-
              Trouble code C-6756 may occur
              [Countermeasure Firmware of the Occurrence Models]
              Model
              Countermeasure firmware
              bizhub C750i
              G00-J9 or later version
              bizhub C650i/C550i/C450i
              bizhub C360i/C300i/C250i
              bizhub C3320i
              • BLord
                • May 2023
                • 1
                When I was writing a literary analysis essay and needed to print it, I had the same problem.Error C3926 is a fuser error on some models of Canon laser printers. While replacing the fuser is a common step to correct this error, it may not always solve the problem. Here are some additional steps you can try:
                Turn the printer on and off: Turn off the printer, unplug it from the power source, and wait a few minutes before plugging it back in and on.
                Restart the printer: Press and hold the Stop button for 5-10 seconds until the printer restarts and the Ready light comes on.
                Check for paper jams: Open all covers and trays and look for paper jams or debris that may be interfering with the printer.
                Clean the printer: Dust and debris can build up inside the printer and cause errors. Use a soft, dry cloth to gently clean the inside and outside of the printer.
                If none of these steps resolve the C3926 error, you may need to contact a printer repair professional for further assistance.
                • Synthohol
                  Certified Konica Expert
                  • Mar 2016
                  • 5840
                  i blame bath salts.
                  Florida? really?
                  like your state doesn't have enough problems?
