C-224e: MFP Controller Download N.G.
  • CP-1015
    • Nov 2020
    • 307
    #31
    Re: C-224e: MFP Controller Download N.G.
    Bad BlockCount.
    • CP-1015
      • Nov 2020
      • 307
      #32
      Originally posted by Synthohol
      Ive see that happen after using the reset tool and not inputting the machine and type back in.
      Make sure it's not set to ff for both.
      I didn't use a SSD reset tool, ever. I didn't have one, because I didn't need. It's the original SSD Board with original counter and number. Is SSD reset for using a used SSD Board with original MFP Board necessary?
      • CP-1015
        • Nov 2020
        • 307
        #33
        One of customers employees cleaned with vacuum cleaner developer. After mounting new developer and two new drums with new blades, only those units were resetted. Customer don't want complete new units, because it's cheaper and more environmentally friendly to change only defect parts.
        After mounting a used FK-511 issue occurs during updating firmware. SSD updating form V6.01 to V6.03 proved defect SSD board.
        There is no way for criminalization.
        • Walterj
          KONICA MINOLTA
          • Jun 2017
          • 89
          #34
          Originally posted by CP-1015
          Stick: 2GB
          Firmware: G20-M1 and GDP-M1
          Tested with new stick, withaout ADF, FK-511 and HDD.
          No chance toget in service mode.
          Last possibility change with used MFP included SSD?
          Thanks advanced!
          I recommend that you perform the physical and logical formatting of the SSD, you do that by deactivating the HDD first.
          Then when you go to rewrite the FW select the Machine and Type well.
          First I select Boot Rom and you give it Start, then you just update all the boards.
          • diksiunix6624
            • Jun 2022
            • 3
            #35
            Stick: 2GB
            Thanks advanced!
            Hi
            maybe you can follow this guide on the youtube
            Fixing Firmware N.G Message| Konica - YouTube
            reconnect the SSD / TPM Board on the MFP Board and try to install the firmware again
