C-224e: MFP Controller Download N.G.
  • CP-1015
    • Nov 2020
    • 323
    [Error Code] C-224e: MFP Controller Download N.G.
    Stick: 2GB
    Firmware: G20-M1 and GDP-M1
    Tested with new stick, withaout ADF, FK-511 and HDD.
    No chance toget in service mode.
    Last possibility change with used MFP included SSD?
    Thanks advanced!
  • copier tech
    • 8172
    Re: C-224e: MFP Controller Download N.G.
    Originally posted by CP-1015
    Stick: 2GB
    Thanks advanced!
    Try just updating the SSD FW v6.03 on its own first then reboot & see if the machine comes to ready.
    SSD Firmware Board Info.pdf
    • copyman
      Owner / Technician
      • Sep 2005
      • 4718
      If all else fails try starting machine with USB service port cover open but no USB stick in it. This should allow machine to boot so you can get into service mode to format HDD, etc.
      • Synthohol
        Certified Konica Expert
        • 5847
        double check the machine and type from a FW stick.
        always use the ssd that came on the machine you are fixing.
        the machine and type are based off the serial# and an incorrect setting will stop mfp fw to take.
        • emujo2
          • Mar 2017
          • 1579
          1. Press Menu.
          2. Select Counter.
          3. Select Display Keypad.
          4. Access Service Mode
          5. Enter CE if enabled
          6. Select System 2.
          7. Select HDD and set to "Uninstall".
          8. Select State Confirmation.
          9. Select Memory/HDD Adj.
          10. Press down-arrow 2/2.
          11. Select SSD Format.
          12. Select Logical Format.
          13. Power MFP OFF/ON.
          14. Repeat steps 1 through 5 to access Service Mode.
          15. Select System 1.
          16. Select Initialization.
          17. Clear All Data.
          18. Select System 2.
          19. Select HDD and set to "Install".
          20. Power MFP OFF/ON. \
          21. Repeat steps 1 through 5 to access Service Mode.
          22. Select State Confirmation.
          23. Select Memory/HDD Adj.
          24. Use the down-arrow to access page 2.
          25. Select HDD Format.
          26. Select Logical Format.
          27. Power MFP OFF/ON.
          28. Try firmware again.
          If this fails order new SSD board. E
          • CP-1015
            • Nov 2020
            • 323
            Where I'll check "different SSD Board firmware is necessary for Zeus MLK Seriesand for Zeus BK Series"?
            Thanks!
            • mojorolla
              The Wolf
              • 2627
              I have run into that Invalid Memory message too many times.
              This procedure has worked a few times for us.
              KM USB Formatting.pdf
              • CP-1015
                • Nov 2020
                • 323
                Stick is cleaned and formatted with diskpart.
                • tsbservice
                  Field tech
                  • 8020
                  Try what emujo suggested. This is recommended procedure.
                  • CP-1015
                    • Nov 2020
                    • 323
                    Please can anybody give me the firmware in attached picture. Thanks!Firmware C-224e.JPG
                    • copier tech
                      • 8172
                      He already said he can't get into service mode.
                      • CP-1015
                        • Nov 2020
                        • 323
                        Originally posted by emujo2
                        1. Press Menu.
                        2. Select Counter.
                        6. Select System 2.
                        17. Clear All Data.
                        Thanks, I tested successfull with an other machine, where I'm able to reach service mode. But this is not booting. I'm no Minolta dealer - I can't order a SSD Board. That's the reason I would try with DLGB1401776EN. Can anybody sent me, please?
                        • emujo2
                          • Mar 2017
                          • 1579
                          Yes, my procedure is based of the ability to enter service mode..Have you tried to get into SM using trouble reset? E
                          • CP-1015
                            • Nov 2020
                            • 323
                            Yes, without success.
                            • emujo2
                              • Mar 2017
                              • 1579
                              There is a reset tool that might help you, it may help get the machine into a state where you can enter service mode. Someone on the site might be able to provide it to you..I think if you actually have a damaged main board or corrupt SSD this may not help either. E
