8 series PageScope not working
  • rrrohan
    • Sep 2011
    • 1977
    I have a C308 that has no access to PageScope but can print and scan ok.
    Remote panel (server) works
    If you open built in Web Browser and go to http://localhost/ it loads fine as well
    Cleared cookies, tried mutliple browsers. Tried connecting my laptop via crossover cable.
    Running latest firmware. Tried v4.2, 4.1, 2 - nothing helps
    You can see it tries to load because it changes from http://192.168.0.50/ and adds the /WCD extension indicating it knows what page to load
    Telnet 192.168.0.50 80 also fails
    Not really sure what to try next
  • tsbservice
    Field tech
    • 8077
    Re: 8 series PageScope not working
    PSWC disabled from copier panel?
    • emujo2
      • Mar 2017
      • 1579
      Doubt it..he can open the web page directly from the built in web browser. My next step would be from a laptop connected directly. If this works then possibly some appliance or managed switch, or VlAN mis configuration..E
      • tsbservice
        Field tech
        • 8077
        You can try this:
        1. Select Utility
        2. Select Administrator
        3. Select Settings
        4. Select Security Settings
        5. Select Security Details
        6. Select Initialize
        7. Power Cycle the device
        8. Test PSWC
        • copier tech
          • 8236
          [ATTACH=CONFIG]48551[/ATTACH]
          You say you tried the latest firmware but not what version?
          • copier tech
            • 8236
            Originally posted by allan
            Strange. What happens if you plug in directly to a laptop? If that works then its a restriction on the customers network.,
            He said he tried that.
            • Bix
              • Apr 2018
              • 1421
              It happened to me after changing the dispwitch and doing a firmware update. Just turn it off and on again.
              If no previous skill function, address book backup and clear all data.
              • rrrohan
                • Sep 2011
                • 1977
                GC3-X4
                • copier tech
                  • 8236
                  GC3-X4
                  Try the latest version GC7-X4
                  • rrrohan
                    • Sep 2011
                    • 1977
                    ill try. im not holding me breath though. figure ill have to do a all clear
                    • copier tech
                      • 8236
                      Yeah last resort you can back up the settings first so no big deal.
                      • rrrohan
                        • Sep 2011
                        • 1977
                        When I format HDD it came up with this
                        Sent from my Pixel 4 XL using Tapatalk
                        • tsbservice
                          Field tech
                          • 8077
                          Corrupted data as Chromium is what machine is based for web interface.
                          • rrrohan
                            • Sep 2011
                            • 1977
                            Yeah it's all good after full reset
