Konica pro 1100 c-2802 low density
  • Lordnixon
    • Jul 2017
    • 18
    After replacing the developer, I have the error c2802. Adding toner to the block solves the problem for several thousand prints. So far, I have ordered TCR, TCB, but I am not completely sure that they will help(delivery times are long). The intermediate block is full, it works during printing, but the toner still goes away (in spurts, in the SM it is specified as normal work)
    count 4kk
    Before that, the error appeared on the previous planned replacement of the developer, but everything was resolved by itself. Unless the density was not so great. Adjusting the expert settings helped(offset to low, max density).
    1) idc - clear
    2) IO check motors -OK
    3) FW g00-90
    4) icp 201 -OK
    5) hopper -OK
    (in check mode ok. are gear slips possible in normal operation?)
    6) recall data in process adj not active, but 91-00
    was completed
  • allan
    RTFM!!
    • 5462
    Re: Konica pro 1100 c-2802 low density
    Simple question did you initialize the developer after replacement? Service mode > Process adjustment > Peculiarity adjustment > Toner density sensor init.
    Whatever
    • Lordnixon
      • Jul 2017
      • 18
      yes
      moreover, I replaced the new developer again
      • allan
        RTFM!!
        • 5462
        Originally posted by Lordnixon
        yes
        Ok just double checking.
        How old is the drum and charge components in the machine. How is the print density? If you go to Service mode > Machine adjustment > Copy density adjustment > Print screen or follow menu numbers 1,3,6,2. You can use the machine as a copier even if it has error codes on it. I do that to use the machine if i have to wait for new developer due to the error C2803. If you use this mode how is the density of the copies.
        It could be as simple as one of your PM parts that is over life and causing poor correction patches.
        Change drum, dev and charge at the same time will assure that patches will be developed properly.
        Whatever
          Haven't seen any mention if OEM supplies being used or not.
          • Lordnixon
            • Jul 2017
            • 18
            charge parts, drum, dev was replace at the same time, sorry
            • Lordnixon
              • Jul 2017
              • 18
              не видел никакого упоминания, используются ли OEM-поставки или нет.
              Отправлено с моего SM-G960U с помощью Tapatalk
              только оригинал
              • tsbservice
                Field tech
                • 8053
                только оригинал
                Translated:
                Only original.
                • allan
                  RTFM!!
                  • 5462
                  Looking at the sample images the density is very low.How was the density just after replacing the developer? If it was nice and solid then it could be a toner supply issue or bad sensor values from the TCB.
                  Whatever
                  • Lordnixon
                    • Jul 2017
                    • 18
                    Translated:
                    Only original.
                    Used original parts, original toner, etc. Sorry, my English level is not that high.
                    • tsbservice
                      Field tech
                      • 8053
                      No need to worry just use translator and right technical knowledge.
                      You literally have to stick to allan advices that man knows his stuff...and many more
                      • Lordnixon
                        • Jul 2017
                        • 18
                        it was nice and solid ^^ after 100 full coverage prints - look 2nd image. In normal printing mode, about 5k will be printed before the density drops and another 3-5k to c2802
                        1. I'm also leaning towards to TCB or TCRS. waiting for parts
                        2. the toner is delivered in small portions only during printing. I don't know if this is normal
                        • allan
                          RTFM!!
                          • 5462
                          Then to wait and see if the TCB and TCRS makes the difference. Keep us posted.
                          Whatever
                          • allan
                            RTFM!!
                            • 5462
                            In normal operation the motor on the sub hopper pulses continuously. Short rotations.
                            Whatever
                            • allan
                              RTFM!!
                              • 5462
                              Ok got this advise form a big KM importer. Have not tried this myself but will have a go at it when i am faced with the C2802 and C2803 error codes.
                              Said that this works. Difficult to except the solution.
                              Remove the frosted lens from the IDCS exposing transmitter and receiver part of the sensor.
                              If you do this please let me know is that makes a difference.
                              Don't discard the developer just tone it up and initialize it again.
                              Also if you do the particularity > gama auto adjust check the error it gives there and check the meaning in the service manual.
                              Under Service mode > Machine Adjust > IDC Sensor adjustment should be done in the case of poor density or sensor replacement.
                              Whatever
