Konica pro 1100 c-2802 low density
  • Lordnixon
    • Jul 2017
    • 18
    #16
    Re: Konica pro 1100 c-2802 low density
    Originally posted by allan
    Remove the frosted lens from the IDCS exposing transmitter and receiver part of the sensor.
    If you do this please let me know is that makes a difference.
    Do you mean a protective film or a light grey film covering the sensor itself? I thought about it and I just never did it.
    • allan
      RTFM!!
      • 5462
      #17
      Yes the plastic layer covering the sensor.
      Whatever
      • Lordnixon
        • Jul 2017
        • 18
        #18
        Ok got this advise form a big KM importer. Have not tried this myself but will have a go at it when i am faced with the C2802 and C2803 error codes.
        Said that this works. Difficult to except the solution.
        Don't discard the developer just tone it up and initialize it again.
        Also if you do the particularity > gama auto adjust check the error it gives there and check the meaning in the service manual.
        Under Service mode > Machine Adjust > IDC Sensor adjustment should be done in the case of poor density or sensor replacement.
        I did it. Now error c-2803 Well then there really were no problems with spot detection
        This is the way...(c)
        • allan
          RTFM!!
          • 5462
          #19
          So you think the IDC sensor is working ok?
          Did you get the replacement IDCS?
          What error do you get if you run auto gama adjust?
          Whatever
          • allan
            RTFM!!
            • 5462
            #20
            Then scrap that idea. Mmm
            Whatever
            • Lordnixon
              • Jul 2017
              • 18
              #21
              I'm not sure, ofс.
              I'll get it in 2-3 weeks
              c-2803
              На датчике 2 слоя. Первый защитный можно снимать без последствий. Второй матовый слой на предположительно исправном датчике снимать не рекомендую. Вернуть в исходное состояние будет сложно.
              • Lordnixon
                • Jul 2017
                • 18
                #22
                TCB replacement is unsuccessful.
                A few days later, the TCRS was replaced. Successfully.
                At the moment, more than 200k copies have been printed.
                • Toxic
                  • 698
                  #23
                  Could this be your problem from start?
                  Nowadays OEM toner too could cause problem and make difficult to figure out what is problem with some strange errors...
                  Bizhub 1100_NG toner.pdf
