what models from 4 series correspond to minolta c452
  • araven666
    • 14
    Hello, I have 2 minolta c452 and wanted to buy a new one to rebuild both but the seller only keeps 4 - series at stock so I was wondering if parts from 454/554/654 are compitable
    Having in mind IU , fuser , tranfer belt.
    Thanks in advance
  • escalante
    • Sep 2018
    • 115
    Re: what models from 4 series correspond to minolta c452
    Hello.
    1.- The imaging unit is almost the same, the only difference is the developer
    2. - The fusion unit is different is not the same
    3.- The transfer band is the same.
    In colors. The Bizhub C654_ C65e_C754_C754e
    In monochrome Bizhub 654_654e_754_754e
    Enviado desde mi Infinix X656 mediante Tapatalk
    • Toxic
      • 697
      If you are not very expirienced with bizhubs i would not advice you to go to that adventure you planed.
      You may spent lot of money with no result.
      Way better solution is to order original parts, i just check in my price lists from KM, almost all is still avaliable for ordering.
      It is little bit expensive parts and maybe not worth investing in that old machines...
        • 14728
        Thanks in advance
        There is nothing that will directly fit from a C454 to a C452. Besides the speed, they are totally different machines.
        • emujo2
          • Mar 2017
          • 1579
          I just canceled 2 maint contracts as supplies/consumables are not available. Not everything is gone, but enough that I can't service contracted customers. E
          • araven666
            • 14
            Thanks for the replies. I was hoping that the next gen was just improved version not completely different assembly. Thank you all for the help
            • allan
              RTFM!!
              • 5462
              I would rather in your case start looking at a C554e.
              Drums and dev units on colors separate and much more cost effective that the image units used in the C452.
              Whatever
