Bizhub 600 Date Time Save Problem
  • manzoorwighio
    • Dec 2019
    • 28
    [Electrical] Bizhub 600 Date Time Save Problem
    Konica Bizhub 600 Date And Time Not Save After Machine Power Off
  • copier tech
    • 7926
    Re: Bizhub 600 Date Time Save Problem
    The back up battery is flat, you can replace these.
    • manzoorwighio
      • Dec 2019
      • 28
      this battery ?
      • copier tech
        • 7926
        [ATTACH=CONFIG]48614[/ATTACH]
        this battery ?
        That looks like it. But is it soldered to the board?
        • rrrohan
          • Sep 2011
          • 1971
          did these support NTP? maybe u can set that up so it resolves it self.
          • emujo2
            • Mar 2017
            • 1580
            Adding NTP won't help to maintain backup data saved in the SSD board. I'm surprised time is the only thing affected. E
            • copier tech
              • 7926
              I had the same issue on a C3110 it would only loose the date/time the battery is only used to store this.
