C759 IU life not reset
  • rrrohan
    • Sep 2011
    • 1977
    I changed a set of IUs in a C759
    One was clipped in properly and gave a C2255 error. I reseated and all was ok how ever IU life did not reset
    The install and yeild prediction date are the same and match the date of install yesterday.
    Any ideas on how to get around this?
    Sent from my Pixel 4 XL using Tapatalk
  • tsbservice
    Field tech
    • 8020
    Re: C759 IU life not reset
    FW latest and correct function version chosen?
    • copier tech
      • 8176
      I would say that when the machine threw the error it corrupted the count.
      But this is no big deal, put a label on the drum with the current counter.
      As mentioned above you could try updating the firmware & function version.
      • byronf
        Senior Member
        • Sep 2017
        • 109
        • tsbservice
          Field tech
          • 8020
          Good idea byronf. Maybe previous engineer activated New Release Disable mode and left the machine.
          • Max
            • Oct 2011
            • 561
            It doesn't last indefinitely. It reverts back to normal mode fairly quickly.
            • rrrohan
              • Sep 2011
              • 1977
              Yeah it wasn't that. I just installed a new drum on same copier and counts for that reset. IUs still incorrect
              • rrrohan
                • Sep 2011
                • 1977
                i just had it on another c759 today
                • rrrohan
                  • Sep 2011
                  • 1977
                  i just checked on CSRC status of the original copier in question and its giving conflicting info
                  Device Home is reporting Parts Life warning on CYM IU but PM parts show 58% which is correct1.jpg2.jpg
                  • Oystercopy
                    • Oct 2009
                    • 623
                    As far as I know, there would be no reason why a new Drum Unit would not reset its respective life settings. UNLESS you were using generic, non-OEM units whose chips did not jive with the machine, for whatever reason. And remember, although you may have new units in there, the machine will still think the units are old and still try to adjust CQ accordingly. If they were OEM units, I would also double check that the chip(s) are not bent down and not contacting the frame for whatever reason.
                    OC
                    • tsbservice
                      Field tech
                      • 8020
                      [ATTACH=CONFIG]49328[/ATTACH]
                      So it's affecting only CMY IUs on both machines. What did you say about FW versions?
                      • blinxwap
                        • Jun 2020
                        • 80
                        I have the same issue on a B758 Replaced the drum unit in march 2021, counter doesnt reset replaced another drum in july & developing unit the dev unit counter resetted not the drum unit would appreciate any help mc has 2.7 mil copies on it firmware X8
                        Sent from my SM-A725F using Tapatalk
