Konica C280 every morning error C-2558
  • ferro10
    • Jun 2015
    • 109
    [Error Code] Konica C280 every morning error C-2558
    Hi The customer tells me that the error c2558 appears every morning
    I replaced the Developer BK unit with a used but with a new chip. The problem did not solve know what can be?
    I was thinking of a problem with HV or the Sub Hopper Assy?
    PS: Sorry for my bad English
  • copier tech
    • 8095
    Re: Konica C280 every morning error C-2558
    Fit a new K dev & image unit.
    Also fit a genuine toner if you are using compatibles.
    • ferro10
      • Jun 2015
      • 109
      Toner is genuine
      I can try with a new developer
      The one I had taken used had very few copies under 50k
      • ferro10
        • Jun 2015
        • 109
        Error list
        IMG 20210319 170721697 — Postimages
        • konicavod
          • Feb 2020
          • 27
          look at the level history 1. take photo.
          print 20 halftone pattern 250 from test mode.
          post photos.
          • ferro10
            • Jun 2015
            • 109
            post photos.
            Ok as soon as I go to the customer I try
            Meanwhile I went to the customer to reset the Developer group again and replace the HV Let's see if the problem recurs.
