C220 firmware update
  • m3a2r1
    • Mar 2021
    • 2
    Does anyone know where I can get the latest firmware for the c220? I need it for SMBv2 support.
  • tsbservice
    Field tech
    • 7990
    Re: C220 firmware update
    Unfortunately SMBv2 is not supported on this model series. You can use scan to internal FTP server behind your firewall.
    • m3a2r1
      • Mar 2021
      • 2
      So maybe something newer than 2011 which I have. I can't get working scanning with Truenas as storage (with smb 1 enabled) and active directory as authorization.
      • tsbservice
        Field tech
        • 7990
        So basically they(manufacturers) want to be selling something newer than model you have and Bizhub C220 is like 10 years old. Surprise - they will not make any effort into updates of 3 generation old model.
        • erayyurukel
          • Jul 2021
          • 2
          [QUOTE=tsbservice;1716202]Unfortunately SMBv2 is not supported on this model series. You can use scan to internal FTP server behind your firewall.[/QUOTE
          I need c 220 firmware update program, if you have it, can you send the file?
          e mail: eryrkl@gmail.com
          • copier tech
            • 8133
            With SMB v1 enabled you should be about to scan via SMB OK.
            We have a few clients that still scan to Win 7 machines without any issues using the C220 series.
            We can supply the latest firmware should you require it please contact us at the links below.
