266i scan to usb?
+ More Options
Posts
  • selmila
    • Aug 2012
    • 133
    266i scan to usb?
    Hi.
    I am unable to set up scan to usb function on bizhub 266i machine!!
    Can anyone help me with the procedure.
    Thanks.
  • Synthohol
    Certified Konica Expert
    • 5888
    Re: 266i scan to usb?
    enable in user box setting in admin mode.
    • emujo2
      • Mar 2017
      • 1579
      We do not have this machine in the US (to my knowledge)..but from past experience, when you pop a USB drive into the slot you should get a pop up asking what you wish to do with this drive. Default settings are to allow you to put a file from the USB into a user box. Print from USB and scan to USB are prohibited by default. If you are seeing nothing when you insert the drive there may be an issue with the drive itself..E
      • Synthohol
        • 5888
        only print from USB "external memory" is on by default, save to box and save to USB are off by default and enabled in the user box setting in admin mode.
        • jwai
          • May 2018
          • 517
          Originally posted by selmila
          Hi.
          Thanks.
          Installed the optional SSD?
          • selmila
            • Aug 2012
            • 133
            Hi.
            The option is enabled in the admin mode and I am able to scan to usb.
            I thank you for your support.
            • emujo2
              • Mar 2017
              • 1579
              Do you have any form of authentication enabled? E
              • tsbservice
                Field tech
                • 8049
                Hi.
                Case is closed
                • emujo2
                  • Mar 2017
                  • 1579
                  Case is closed
                  yeah I read it as "unable to scan"..E
