Bizhub c350 no network settings
  • g3direct
    We recently bought a Bizhub c350 that has seen little use. The only problem it had was that the Fiery was burned out by a lightning hit. We removed that device and the machine worked fine. We were able to print to it from a computer with no problem after the IP was set up.
    The next day the network settings button no longer showed up and we were not able to print to it any longer. I can ping the machine just fine and the windows printer shows it as ready. Any help would be appreciated.
  • 8050
    • 88
    Where your network cable is plugged in, do you still see a link light?
    • g3direct
      The link light is on. The info light blinks occasionally. I checked all the wires, they were all connected. I can ping the machine with no loss of packets. I can not connect to it through my web browser using the IP address that I set for it originally
      • 8050
        • 88
        Well, I'm going to have to ask this, but when you removed the Fiery you did change the controller settings, right?
        • g3direct
          Yes, I tried each of the controller settings to see if it would work. That was how I was able to get it to work right after we removed the fiery.
          • johnj_01201
            • 15
            Go to the copier's web interface. Type the copier's IP address into your web browser. See if this works. The ping reply might just be from another computer on your network. Also, the web interface will give you more details. You could have blown your print controller chip. Some BW copiers do not come with print controller chips and cannot print, but they can be pinged and also scan. You may have to check to make sure the machine has the correct controller setting, in case it did not stick.
            • TheOwl
              • Nov 2008
              • 1732
              To eliminate everything else in your network, try connecting a latop via a crossover cable directly to the copier. See what happens then.
              I also believe that the standard peripheral setting should be 'Controller 3'.
              • g3direct
                I can not connect to the machine through my browser. It's IP address is not near any other computer and when I scan the network it shows up at the correct IP. It is the only Konico we have so it's obvious that it is the correct machine. I have tried each controller setting, none of which worked. It printed just fine for a day. The next day it stopped working. So I don't see how the print board could fail that quickly.
                • Albonline
                  • Sep 2008
                  • 1151
                  at copier is the network button showing up? utility /admin/network. ?
                  • kmcopier
                    PSP
                    • 183
                    Controller type 3 is correct (default machine).
                    Initialize
                    the machine see page 3-104 SM after that start the machine up without connected too the network (DHCP server bootP ARP). Make your network settings gr kmcopier
                    • timcouch
                      I had a very similar problem with mine. I tried everything i could think of then changed my port settings on the print server. I used LPR and put the Queue name as print. This is what got my machine to print. I had the board replaced, changed print servers, network ports, everything i could think of and this works great. If i change it back to RAW everything stops. Hope this helps.
                      Tim
