Konica Minolat C200
  • theyikes
    • Apr 2021
    • 2
    [Misc] Konica Minolat C200
    HI! I have a Konica Minolta C200 printer. I'm trying to set it up as a network printer. My question is how do I access the network configuration section? Currently there is no network cable attached and there is no network option that I can find, Does it need to be plugged into the router to enable the network settings section?
    Re: Konica Minolat C200
    request a service manual here: https://www.copytechnet.com/forums/s...nual-requests/
    being an end user you should also also review the forum rules: https://www.copytechnet.com/forums/misc.php?do=vsarules
    • emujo2
      • Mar 2017
      • 1579
      The C200 was old when I started working on KM 15 years ago..there is not much out there, but I was sable to find this..
      NC-504 is needed for TCP/IP printing/scanning.
      There may be a USB port where this NIC would have been..There is no support (drivers) past Windows 8 ( I was actually surprised by this)
      E
      • theyikes
        • Apr 2021
        • 2
        E
        Thanks you so much for replying with something other than a redirect. There is both a USB port and a CAT45 connector beside it. I'm just wondering if there may be an issue with the network card?
          redirect ?
          I showed you where to request a manual! most techs don't try to work on something WITHOUT a manual ... being an end user I would highly recommend getting one...
          but I'm sure Copier Tech would be willing to sell you one.
          • tsbservice
            Field tech
            • 8053
            Plug in network cable from your switch into machine did you see the light on port is on?
