Bizhub c250i squeaking noise
  • Cantechman
    • Nov 2008
    • 228
    I have a c250i with only 20k, it randomly will make a squeaking noise (like a bad bearing type noise) for a minute or so while the machine is not being used, happens very randomly. I couldn't get to happen while I was there so i tested another fuser, the next day it happened at idle again just for a minute. Any ideas other the replaced fuser?
  • mojorolla
    The Wolf
    • 2599
    Re: Bizhub c250i squeaking noise
    I wouldn't describe it as squeaking, but there is a known issue with the fuser drive pack making noise at idle. There are a few threads about this on this forum I believe....
    • occus
      • 332
      Check other posts here and the paper exit drive
      • Gift
        • Mar 2011
        • 2459
        See if the noise disappears if you fiddle around the idle rollers away from the paper exit rollers.
        • mojorolla
          The Wolf
          • 2599
          But don't fiddle around with it too long, you'll go blind
          • byronf
            Senior Member
            • Sep 2017
            • 109
            Hi,
            This is common on this range, issue is the waste toner box screw just lubricate and sorted.
