DR314K vs DR313K
  • tsbservice
    Field tech
    • 8076
    DR314K vs DR313K
    Anyone have experience using 8 series K drum(DR313K) in 8e series machines(DR314K).
    I know Konica say to not use DR313K instead of DR314K.
  • Gift
    • Mar 2011
    • 2459
    Re: DR314K vs DR313K
    It would require some work and modification/parts swapping because there are several differences "built-wise" like different lenght of the waste toner exit thingy, charge plate, etc. It's probably easier to rebuilt the DR314 with stripped parts from the DR313.
    • Woxner
      • Jul 2011
      • 854
      The 8 series will fit the 8e with no mech problem. It will however not last as long. Maybe 50 to 70% life. The 8e does not work in 8 series
      • tsbservice
        Field tech
        • 8076
        Thanks Woxner that is what I was asking for as 8 series drum is half the price 8e.
        • tmmdmmm
          • Apr 2021
          • 173
          At the same time, I have 313k estimated life at 150k and 314k life at 270k. Close enough to 50% rated, if the 313k works in a 8e might be easier to just carry those and replace them twice as often on the very few 8e machines I have
          quick edit: But I was also curious about this from a call last week, didn't want to risk ruining a 313k testing it out though
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            Exactly, since I've done it on accident the first time I needed to replace a failed drum on a 308e. I grabbed the 8 series drum I had and it worked fine. It went into a machine that's in an extremely dirty environment and has lasted much longer than the original correct 8e drum did, so far anyway.
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
