Fiery C658
  • rrrohan
    • Sep 2011
    • 1977
    Fiery C658
    Having trouble with Fiery
    Replaced it's HDD.
    Reloaded software.
    Installed on copier.
    Fiery button appears in menu but I get the attached errors.
    I can access it via machines web browser on 172.17.249.1
    I ran intial setup
    Copier gets a fiery address of 172.17.249.2 and a LAN IP.
    Can print direct to machine via it's 192.168.0.33 address
    Fiery address won't work.
    Also if I try to enter network settings on copier the "failed to connect to controller" msg and boots me back to menu if I click ok
    No idea what I'm doing wrong
    Sent from my Pixel 4 XL using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5737
    Re: Fiery C658
    the fiery should be at 192.168.0.32 as it assigns the copier 1 number up from itself.
    the 172. address is just a dummy address displayed.
    • emujo2
      • Mar 2017
      • 1580
      Re: Fiery C658
      Shot in the dark, but try turning off SSLv3 on the MFP side. E
      • rrrohan
        • Sep 2011
        • 1977
        Re: Fiery C658
        im a fiery noob.
        i updated firmware, set to v4.2 disabled IP filtering and enabled RAW printing
        something fixed it in that process.
        I assume there is a installation guide but my supervisor said he only had it for the older Windows based fiery
        anyway got it working, thanks
