Bizhub 363 Error C-C152
  • tulintron
    • Jul 2014
    • 669
    Hello everybody. This old BH363 with error C-C152 appeared in our laboratory after improper updating. Documents state FW change after Japan earthquake. According to the documentation, I have FW needed for solution, but I can't finish it. Always features C-C152. As an old printer, I believe that someone here has been there before. Need help. Thanks
    Earthquake Bulletin
    Firmware Documentation
    Final Result
    The Firmware Documentation file has the step by step on the last pages. I followed, but I was not successful.
    Thanks for any help
  • Synthohol
    Certified Konica Expert
    • 5804
    Re: Bizhub 363 Error C-C152
    The 3 series has Stand alone scanner firmware.
    I used to run into that a lot before the series was discontinued.
    If you don't have access to it PM me and I'll help you out.
    • Synthohol
      • 5804
      G8x-09 is the scanner only firmware for the whole 3 mono series.
      I'll have to add it to my server later when I get home and give you the link.
      • tulintron
        • Jul 2014
        • 669
        These FWs I don't have.
        • tulintron
          • Jul 2014
          • 669
          Synth, due to my English, we may not communicate well. I have the G00-C8 FW version.
          There are 03 FW in it.
          G00-02 = BootRom Ver.
          G00-09 = G8X-09 Scanner Ver.
          G00-C8 = Mass Product. Ver.
          For each CPU altered due to the earthquake, the G8x-09 file performs the correct FW. In my case, H8S / 2324 would be the G00-09.
          These files I have with me.
          The FW G8x-09 (Scanner Ver.) Recognizes the 04 CPU below:
          H8S / 2324: A1UD0Y0-0023-G00-09 Check Sum 0DDA
          H8S / 2325: A1UD0Y0-0023-G80-09 Check Sum 7F0E
          H8S / 2424: A1UD0Y0-0023-G82-09 Check Sum BA94
          H8S / 3006: A1UD0Y0-0023- G81-09 Check Sum F469
          Procedure performed according to documentation, but without success.
          • Synthohol
            • 5804
            The d6 firmware I linked is the latest, yours was older.
            Flash the d6 firmware and if the scanner still says ng use the scanner only fw I linked.
            • tulintron
              • Jul 2014
              • 669
              Originally posted by emujo2
              Are you sure you are looking at this correctly..
              Program Name File Name Checksum Note
              Scanner (H8S/2324) A1UD0Y0-0023-G00-09 0DDA
              The Board number for the MFP board mounted with the current microprocessor (H8S/2324) :
              A1UDH020/A1UDH021
              Which MFP board do you have?
              This is my board - (H8S/2324) :
              A1UDH020/A1UDH021
              • tulintron
                • Jul 2014
                • 669
                I did so many procedures that I can't explain which one allowed me to update the scanner with the G00-D6 version.
                We finally made it. Thanks again, Synth.
                • Synthohol
                  • 5804
                  thats what we are here for
