C3320i and fan noise, even in sleep mode
  • olivenoire
    • May 2021
    • 39
    Hi, I'm the owner and end user of a C3320i.
    I've bought it cash a week ago, no monthly fee for maintenance or whatsoever etc. (will print max 250 sheet a month).
    The machine was initiated by the local KM dealer.
    I've succeed to setup everything I need, Wifi, scan to mail, easy thanks to admin password I've find on the net
    my complain is fan noise. FM1 and FM2 constantly turn on even in sleep mode.
    Is there a way to go in a more deep sleep mode?
    For sure I've tried the service mode. But the 16 digit code from the service manual was changed.
    2 questions :
    - is it possible to setup or turn of fan when in sleep mode
    - If yes, in admin mode or service mode
    regards,
    PS : I've check the consumption. In sleep mode constantly @ 9W
  • rrrohan
    • Sep 2011
    • 1977
    Re: C3320i and fan noise, even in sleep mode
    What's service code did U try?
    I'd do 92729272 or
    9272927292729272
    Sent from my Pixel 4 XL using Tapatalk
    • avecosat
      • Jun 2012
      • 305
      Service mode : Engine FW 37 OFF to ON ( silent mode level )
      • olivenoire
        • May 2021
        • 39
        I'd do 92729272 or
        9272927292729272
        I've try both. Obviously the dealer changed it. Will give a call tomorrow.
        • olivenoire
          • May 2021
          • 39
          Thank you,
          Will save me time as soon I will have access to service mode.
          Sad the seller did not do it by itself.
          • rrrohan
            • Sep 2011
            • 1977
            Originally posted by olivenoire
            Thank you,
            if you have access to escalations you can just request a reset code to clear the service passwords
            • tsbservice
              Field tech
              • 8076
              Looks like enduser to me.
              • rrrohan
                • Sep 2011
                • 1977
                edit : wrong thread
                • olivenoire
                  • May 2021
                  • 39
                  available for end users?
                  • tsbservice
                    Field tech
                    • 8076
                    None
                    • olivenoire
                      • May 2021
                      • 39
                      And finally, the seller accepts to give me his Service Code.
                      As a result I will be able (I hope) to configure this
                      regards,
                      • olivenoire
                        • May 2021
                        • 39
                        I've found "software switch". But where is engine Switch?
                        • olivenoire
                          • May 2021
                          • 39
                          wrong post
                          • olivenoire
                            • May 2021
                            • 39
                            Find!!!! Thanks service manual
                            Easy
                            Edit : now, after "force sleep", the machine auto get out of sleep mode??
                            • olivenoire
                              • May 2021
                              • 39
                              Some news :
                              Machine does not stay anymore in deep sleep mode.
                              Short press : goes sleep mode, fan on even with flag 37 on
                              Long press : goes in deep sleep mode, then immediately goes out of sleep mode
                              Any idea?
