C3320i and fan noise, even in sleep mode
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    #16
    Re: C3320i and fan noise, even in sleep mode
    Originally posted by olivenoire
    And finally, the seller accepts to give me his Service Code.
    As a result I will be able (I hope) to configure this
    regards,
    Being a end user you could do more damage than good contact supplier again and get them to sort.
    Regards Mark
      +1 no end user should have access to Service Mode... quick way to brick a unit!
      • olivenoire
        • May 2021
        • 39
        #18
        okay understood
        • olivenoire
          • May 2021
          • 39
          #19
          just want to state.
          Yes I'm an end user, and you are right it could be dangerous.
          I have to admin it is strange to enter in service mode only to turn off the fan in "deep sleep mode".
          Anyway, reading carefully the service manual as the engineer am I, I found it is not a complex task. I will not try to update the FW or something like this.
          You are right there is a risk to brick it and I don't want.
          I've finally succeed.
          I just have to admit menus and / or submenus are a bit weird and not very clear or logic. But not impossible to understand .
          And power setting are weird to. How the hell it is possible to put "power setting" under "maintenance and Timer setting". So strange!!
            • 23010
            #20
            I'll be the first to say that the menu arrangements are not always logical. =^..^=
            • olivenoire
              • May 2021
              • 39
              #21
              For the first time I found menu arrangements worse than my Nikon Z6. lol
              Anyway the strange thing is this machine can't go on silent mode by itself, I need to force long press to power button. So uncommon ...
              And in this case the printer can't print but manual press on button to wake up.
              real mess
              • tsbservice
                Field tech
                • 8081
                #22
                Power settings are in System settings, from there you can change the time machine enters Low Power Mode and Sleep mode (available range: [2] to [60] minutes).
                • [Utility]
                  • [Utility]
                    • [System Settings]
                      • [Power Settings]
                  • [Utility]
                    • [Utility]
                      • [System Settings]
                        • [Power Settings]
                  this cat is an end user... he shouldn't be playing in admin mode.. nor any mode IMHO
                  • tsbservice
                    Field tech
                    • 8081
                    #24
                    Yes I know Phil. By default these settings are restricted to the users by Administrator.
                    Imho these days so much settings can be scr..d by users, admin or even a tech. Those machines are getting more and more sophisticated, many functions are binded with other etc.
                    • olivenoire
                      • May 2021
                      • 39
                      #25
                      • [Utility]
                        • [Utility]
                          • [System Settings]
                            • [Power Settings]
                      Thank for information.
                      The real problem is this printer makes it's fan constantly on. Low power or sleep mode do not change anything. Need Service mode, not even Admin mode. So strange.
                      • olivenoire
                        • May 2021
                        • 39
                        #26
                        Sorry English is not my mother tongue.
                        You are right, but I'm not only end user but owner too.
                        I'm okay with you, I should not play with service mode.
                        But to make the printer Silent in sleep mode, it is mandatory. Even Admin does not offer this. Not normal IMHO.
                        Timer does not help go the printer in silent mode.
                        Also I have to use admin mode to configure SMTP, scan to mail etc
                        About service mode :
                        there is nothing too complex. I mean, I will never change the mother board or other important parts. I will not reset counter nor change serial number.
                        I will not do something I do not understand after carefully read the service manual.
                        What I think for what I need in Admin mode :
                        Nothing too complex but strange menus structure. Probably with time, it will be easier.
                        About eco / sleep:
                        Obvisously this a weak feature at Minolta. Not easy to setup a silent mode and in "deep sleep" the only to turn off the fan, the printer will no longer receive data from network. I mean if not in deep sleep mode + SW 37 on, the consumption is 9W and FM1 + FM2 on. In my case, the real problem is ir is too noisy in a little office.
                        To summarize : c3320i (and maybe others KM) got a real problem of conception. They should be silent by default.
                        PS : At least I've learn lot of thing. My next copier will be a Ricoh Probably a C300.
                        • tsbservice
                          Field tech
                          • 8081
                          #27
                          This time you did wrong selection. With small A4 color AIO MFPs you need to go with Ricoh not KM.
                          A3 color models are different story in this segment KM sometimes even excels Ricoh and other brands.
                          • olivenoire
                            • May 2021
                            • 39
                            #28
                            In fact my first choice was Ricoh. Already work with them, great copier in my mind.
                            But the reseller does not offer me to sell without a contrat, which I do not want. So I decide to black list this seller.
                            Xerox is a no go.
                            Other brand, don't know.
                            As a result I go KM (c3320i get a really small foot print). I have no regret except this little "noise" problem.
                              • 23010
                              #29
                              One last thing before I drop this: There is a reason to have fans that run constantly. The power supply, and often the fuser are generating heat constantly, and the heat must be dispersed or the MFP will overheat. Silent mode shuts down the print engine, but the power supply is still generating heat always. The noise "problem" is, in my mind, the normal operation of the device.
                              If the printer is so close to you that the "noise" is unbearable, maybe the printer should be located somewhere else.
                              Ok, I'm done. =^..^=
                              • occus
                                • 339
                                #30
                                Yes it is true this series 3320i/3350i/4050i have a noisy fan for the cpu. I asked KM if there was a solution, but there wasn't one.
