Strange prints think developer might be empty
  • positiveg
    • Jun 2018
    • 299
    Hi there guys,
    Now I've had a similar issue when my black developer was running out.
    Am I right to suspect this coming from the Cyan developer?
    Sent from my SM-G955F using Tapatalk
    Re: Strange prints think developer might be empty
    Originally posted by positiveg
    Hi there guys,
    yup classic signs
    • tulintron
      • Jul 2014
      • 668
      Hi there guys,
      Target shooting!
      • positiveg
        • Jun 2018
        • 299
        Yup confirmed it. Trying to get developer in
        • drowranger
          • Jul 2015
          • 122
          Please check the magenta and cyan drums as well. red line in the corner suggests magenta drum its most likely need to change.
          if this is a 4 series device(224e/364e/454e/554e) ; there is common issues with the hopper bushing and toner empty sensor causing this .
          more info https://www.copytechnet.com/forums/konica-minolta/148470-konica-minolta-bizhub-c224e-c-2557-error.html?148470=#post1486885
          hope this helps
          • femaster
            • May 2011
            • 1512
            If the cyan drum is near or beyond life, replace that at the same time as the dev unit, or you may drain your new unit. Has happened to me a couple times when I was in a hurry and forgot to check the drum life... Second time was more than enough for me, now if a dev unit drains before it's time, the drum gets replaced at the same time. Haven't lost a second dev unit since.
            • CP-1015
              • Nov 2020
              • 323
              Hi there guys,
              What's about magenta on the left side?
              • tsbservice
                Field tech
                • 8020
                Drowranger already spoken about that.
                  hey brother tried to PM you but your inbox is full.. tells me you need to clear some space.
                  • tsbservice
                    Field tech
                    • 8020
                    Some enduser filled my quota just today. Leaved it like that to avoid spam. Cleaned now
                    • REGSIS
                      • May 2016
                      • 435
                      Can happen with new drums too. Had many of these on countert above 200k total.
                      Always cleaned dev unit and drum unit (charging unit) soiled with cyan toner.
                      Vacum excess toner on dev unit especially on side of magnet roller. Rotate magnet rlller backwards to extract dust an toner from the bottom.
                      Vacum it from a distance. Do not vacum developer - just particles of dust and toner from surface.
                      Use original toner and dev unit will be like new in a 3k copies.
