KM C554E very clear copies and prints lacking black
  • tecnomarco
    • Jul 2011
    • 214
    hello to all, I have a KM c554e it worked fine ... it started making clear prints as if there is no toner ... I ask you if replacing dv unit black new solves the problem? ... I tried to insert a group developer used but after a while ago the same problem "COPIES LACK OF BLACK OR LOW DENSITY" ... in your opinion there may be a problem on the toner feeding mechanism? ... I specify that the black toner is original
    Re: KM C554E very clear copies and prints lacking black
    "clear" prints? you mean the pages are devoid of text?
    • tsbservice
      Field tech
      • 8042
      Replace black developing solenoid.
      • progoffice
        • Nov 2008
        • 337
        It sounds like a transfer belt problem. The roller underneath the belt that makes contact with the black drum could be broke and therefore no black toner on the belt or the printed page. I've seen the cams that lift the rollers break before. Anyway, try a new/used transfer belt and see what happens.
        • tecnomarco
          • Jul 2011
          • 214
          i replaced the black group with a used one .... it worked for a while ... but after a few time they are clear it seems that no toner is added in the DV UNIT black
          • tsbservice
            Field tech
            • 8042
            Any error codes?
            • tecnomarco
              • Jul 2011
              • 214
              does not complete the jobs set in this condition a yellow triangle appears
              • tecnomarco
                • Jul 2011
                • 214
                No error
                • tsbservice
                  Field tech
                  • 8042
                  No error
                  Check error history for C25xx codes.
                  • copier tech
                    • 8196
                    If you can post a gradation sample set of test prints YMCK we can tell a lot from these.
                    • tecnomarco
                      • Jul 2011
                      • 214
                      Tomorrow because now is night thanks for your assistance
                      • progoffice
                        • Nov 2008
                        • 337
                        Just last week I had to remove a toner hopper on a C364e machine to free up the black toner supply mechanism. The motor that drives it was locked up and they were getting a C2557 code. I don't think this is your problem though. You should definitely be getting C or P codes with the issue you are having. Also, it's usually the cyan and magenta DV units that fail on these units. I still think you're dealing with a bad or broken transfer belt.
                        • tecnomarco
                          • Jul 2011
                          • 214
                          I have solved this problem.... I change the motor toner black... much good the suggestion check level history 1 for check if DV black Is 6-7 %
