bizhub 420, duplex problem
  • Gab
    • Aug 2015
    • 676
    It makes single sided copies with no problem.
    When doing 2-sided , it prints the first side and when it pulls in duplex unit paper it stops and paper jam. It doesn't try to pull in paper again.
    Re: bizhub 420, duplex problem
    jam code?
    what gsm paper are they using?
    are the duplex rollers clean?
    any visible obstructions?
    as always need more info from you.
    • Synthohol
      Certified Konica Expert
      • 5892
      10+ red cards Phil, why even bother responding?
        trying to be a kinder more helpful Phil B. brother
        • allan
          RTFM!!
          • 5462
          Recall there was a very common problem with switchback sensor actuator un-clipping or breaking.
          Whatever
          • Toxic
            • 698
            Whenever i have this problem on 420/500 it was always grease inside duplex clutches.
            KM long time ago release TAD about this problem.
            Cleaning clutches solve problem for some time but replacing clutches and removing excesive grease from duplex gears is permanently solution.
