C6100 P/N for wheels
  • reckless
    • Feb 2017
    • 188
    Can someone help me figure out the part numbers for the wheels underneath the Konica Minolta C6100? I can't find it in the service manual.
    • 22808
    Re: C6100 P/N for wheels
    part numbers are found in the PARTS MANUAL.
    • reckless
      • Feb 2017
      • 188
      I have the quick manual and service manual. Is there a third parts manual? Forgive my ignorance as I am new to this.
      Also, wouldn't same part be used across ALL accuriopress machines? The little wheels underneath main engine?
        • 22808
        might help if you posted pictures of the little wheels since you don't know the NAME of the 'wheels'.
        no not all parts are used across all lines.. usually different parts for different speed machines
        • Synthohol
          Certified Konica Expert
          • 5534
          i think he means the ones that support the machine.
          front and back are different #s
          • reckless
            • Feb 2017
            • 188
            WhatsApp Image 2021-05-25 at 5.17.16 PM.jpgWhatsApp Image 2021-05-25 at 5.17.16 PM (1).jpg
            Perfect! Where did you get this information? I searched service manual and didn't see it.
            I googled and found the wheels are $70 from a polish website. Is there a good dealer/aftermarket place to buy these wheels?
            The diagram shows 2 wheels my machine has 4. Maybe I missed the other two? I need to replace 2 wheels.
            • rrrohan
              • Sep 2011
              • 1976
              Might be quicker to just go to a decent hardware store and buy some generic ones
              But I guess you'd have to then do all 4 plus any on finisher and LU to be sure they are same height. Yeah maybe just get genuine ones [emoji3526]
                • 22808
                for so,e reason I can't open your attachment...
                your talking about the cabinet wheel? or under the whole machine?
                ok I couldn't gather that from his 'explanation'
                thanks brother.
                  • 22808
                  [ATTACH=CONFIG]49257[/ATTACH][ATTACH=CONFIG]49258[/ATTACH]
                  I always called them "casters"
                  • 40yearsplus
                    • May 2020
                    • 114
                    Ill ask my work Associate tomorrow. There is a Company in Mass. where they are very helpful and can get you most any Konica part you want we have used.
                    We also got the casters.
                    Also you can call a machine wholesaler and ask them if they have any from trash units they have and you can pay for them.
                    • Synthohol
                      • 5534
                      harbor freight, home depot, lots of places to get new castors.
                      even the bottom of a dolly has good castors.
                      better yet, grainger.
                      castor wheel heavy duty products - Grainger Industrial Supply
                      i PM'd you the right pages..
                        • 22808
                        Synth YOU are da man!
                        • methogod
                          • Dec 2008
                          • 915
                          sign up with ACM, they can order koinca parts pretty good prices. that needs to be level, so I wouldn't use an aftermarket caster.
                          • reckless
                            • Feb 2017
                            • 188
                            What is ACM?
                            Nvm, I googled and found them. Thanks for the advice, will order from them. I agree castors need to be same to perfectly level.
                            • reckless
                              • Feb 2017
                              • 188
                              thanks a MILLION! I needed this. Hoping to self service this machine but dont plan on using any finishers, hoping that will make less points of failure.
