Bizhub 224e Fuser
  • tsbservice
    Field tech
    • 7989
    Bizhub 224e Fuser
    Question: Is the bizhub 224e Fuser unit the same as bizhub C224e Fuser unit. I think Yes but the part numbers and the price are different.
    I need to hear from experienced.
    TIA.
  • Toxic
    • 697
    Re: Bizhub 224e Fuser
    I think it is the same thing just different PN.
    Once in hurry situation i put fuser from 368e on C224e and it works ok so it would be logical to can fit also from 224e to C224e.
    • tsbservice
      Field tech
      • 7989
      If I get this in practice I will switch the fusers, the one for C224e is cheap
      • Toxic
        • 697
        In my country it is about 10% cheaper for C224e.
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1250
          TIA.
          I can verify that they are the same fuser. The part numbers changed for the 4e series but they are completely interchangeable.
          • livancicm
            • Sep 2008
            • 96
            220V fuser
            c 2 lamps conector 3 contacts
            b 3 lamps 6
            • tsbservice
              Field tech
              • 7989
              Originally posted by livancicm
              220V fuser
              b 3 lamps 6
              So 230V fusers are different because of wiring?
              • livancicm
                • Sep 2008
                • 96
                wiring and lamps rest is identical
                • tsbservice
                  Field tech
                  • 7989
                  Hmm...according to Service manuals black and color models bizhub 224e and bizhub C224e BOTH have 2 fusing heater lamps(FH1 and FH2). That looks pretty similar to me?
                  • Toxic
                    • 697
                    We should open poll here to find out is it different fusers or not...
                    • zoool
                      • Nov 2016
                      • 52
                      u must change lamp i fusing. this is all
                      • blazebusiness
                        • 1250
                        Well, in the USA 120v fusers are absolutely completely interchangeable. I forget sometimes to take into account the part/voltage differences in the UK. I can't speak with confidence as to the 230v fusers.
                        • danifuenca
                          • Oct 2013
                          • 33
                          In Europe the connectors are differents. You must change the lamp and Thermistor
