hi guys. got bizhubs 600 & 700 both giving same code " c-2401 ", pcl error I think. what holds pcl ? & what should be done ? please help. Boards were mixed between the two. Not main. I put lower print controller w/57BA on the 600 & 57AA on the 750, like supposed to be. still same. what about the flash cards. OK NOW HELP. THANKS
BizHub-600 & 750
Man, Have you tried to check the hardware already ? I mean I/O mode and check the fan.
C-2401
The EM signal shows an abnormalis turned OFF and then ON again.
condition when a specified
period of time elapses after the
developing suction fan (FM4)
turns ON. This abnormal condition
recurs when a specified
period of time elapses after FM4
At first I would check it and then play with boards.
There`s a mistake in the manual c2401 and c2301 have been swapped over. 2401 relates to a disconnected E.L. lamp. Here`s a couple of solutions you can try.
C-2401 at power up.
Solution
CAUSE: C-2401 normally indicates a failed erase lamp, although it is caused, in this case, by a bind in the drum carriage.
SOLUTION: Remove and inspect the drum carriage assembly. Run the Toner Cartridge Set mode as well as the Developer unit/Drum.
C2401 (C-2401)and C2803 (C-2803) codes.
Solution
CAUSE: Open ICP6 on the PRCB.
SOLUTION: Check for broken or shorted wires in Tray 3 area and repair as necessary. Replace the PRCB (p/n 57AA-9020).After replacing the PRCB, go to
the Service Mode and set softswitch 32, bit 1 to"0" (OFF).Then re-flash the firmware and, after restarting the machine, set softswitch 32, bit 1 to "1" (ON).Comment
C-2401 at power up.
Solution
Solution
In Europe is only ,,infohub,, but it is piece of crap.
Cheers
That's my email daniel.zabojnik@gmail.comComment
The PCL is part of the Charge corona assy. ( Pre Charge Lamp )
Is this your Original symptom on both machine before you started swapping boards, or did this happen as a result of board swapping?Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI BoxesComment
board swap then c-2401
I put the correct boards onto correct machines low. print controller 57BA onto 600 & the 57AA onto the 750. that's when I got the 2401 code. I also swapped the drum units around. I had no problems w/code untill the board swap. the drum unit in it is fine. I works in different mach. no problem. There's also ic-202. Some 600 & 750 have them and some don't. I think I've tried all combos but not the flash cards. Please reply. ThanksComment
