YSoft USB READER 3 MF loadable device driver
  • Djolf
    • May 2021
    • 2
    Hi guys,
    I'm buying YSoft USB READER 3 MF for my Bizhubs 227/287/367/C227/C287/C250i/C300i/C257i.
    Where can i find loadable driver for each ?
    Thanks.
  • Albonline
    • Sep 2008
    • 1154
    Re: YSoft USB READER 3 MF loadable device driver
    You need to get in contact with your local Km certified service support.
    • allan
      RTFM!!
      • 5462
      I guess Ysoft should also have access to the KM driver software.
      Whatever
      • emujo2
        • Mar 2017
        • 1579
        You need to be real careful here..you are going to have to use the CCID for all of your machines as KBW mode was not available on your older devices. If you try to use a combo you will get different reads from the same badge at different locations. Ed
        • Djolf
          • May 2021
          • 2
          I can't use the CCID loadable driver, i need the KBW one.
          • emujo2
            • Mar 2017
            • 1579
            In the US..Ysoft KBW driver only available for the 4750i, 360i, 300i and 750i series
