C3070l wrinkling output paper
  • daadoooo113
    • Jun 2021
    • 4
    [Misc] C3070l wrinkling output paper
    Hi everyone!
    I own a Accuriopress C3070l and the output paper is starting to get wrinkled after we changed the fusing belt. First few copies were ok and then the next day the wrinkling occurred. I am attaching a pic bellow. The paper itself is 330x243 mm 115g.
    Thank you for your help.
  • lartis.aineias
    • 78
    Re: C3070l wrinkling output paper
    Originally posted by daadoooo113
    Hi everyone!
    [ATTACH=CONFIG]49405[/ATTACH]
    reduce the temperature, slightly disturb the input fusing plate!
    Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
    • daadoooo113
      • Jun 2021
      • 4
      Will try it, thanks. Could also paper that has been opened for a while cause a problem? Maybe humidity got to it?
      • Toxic
        • 698
        Agreed, try lowering fusing temperature.
        For years on all machines that 115g paper was nightmare to work with, especialy when output is full black or duplex.
        It just wrinkle when get heat in fuser, wrap arround fusing belt,...humidity make things worse.
        Now we are not using it anymore, replaced with 135g and it is much better.
          • 23009
          When you re-assembled the fuser, and you re-installed shoulder screws ... did the shoulder seat properly into the frame? I saw one the other day, that the last tech replaced the shoulder screw with an M4 regular pan head screw. The result is the frame seats 1mm higher, in this case it was the front. And the belt walked to the rear and chewed itself up ... and wrinkled the prints. =^..^=
          • 40yearsplus
            • May 2020
            • 113
            I would recheck your installation of the belt and did you change any fuser pressure?
            You said it began right after the installation.
            Let us know.
