konica c 454 error code D012
  • nabcom2008
    • Oct 2020
    • 1
    [Error Code] konica c 454 error code D012
    please i need firmware update for this machine
    thanks
  • escalante
    • Sep 2018
    • 115
    Re: konica c 454 error code D012
    In this link I could find
    Printers-Copiers Servicing Reference Manual
    Enviado desde mi Infinix X692 mediante Tapatalk
    • Synthohol
      Certified Konica Expert
      • 5922
      there is no cd012 error in the manual or on Konicas database, either way it is likely HDD failure not FW related.
      try and unset the HDD and reboot.
      please report what happens.
        • 15069
        • Yirbuor George
          • Sep 2019
          • 8
          [QUOTE=Synthohol;1809516]there is no cd012 error in the manual or on Konicas database, either way it is likely HDD failure not FW related.
          please report what happens.[/QUOTE
          Do you mean uninstall.
          I uninstall it the error code is gone but I can't print from USB
          • Synthohol
            • 5922
            Right, so re-enable the hdd and do a logical format on it.
            When you reboot it will ask for movie data but ignore that for a bit and make sure the code doesn't come up again.
            Install the movie data and you are all set.
            If still errors then replace the hdd and sata and power cables. They are cooked.
            • Yirbuor George
              • Sep 2019
              • 8
              [QUOTE=Yirbuor George;1811281]
              When the HDD is uninstalled the error code doesn't show.
              • Walterj
                KONICA MINOLTA
                • Jun 2017
                • 89
                thanks
                good day
                If you want the solution of the error CD012 that your machine presents, you can write to me at walvaradocruz@gmail.com
                Greetings.
                • Synthohol
                  • 5922
                  Originally posted by Walterj
                  good day
                  Greetings.
                  dude, the purpose of a forum is so we ALL learn from others experiences and solutions, keeping your response private through email defeats the reason we are all here.
                  just saying
                  • escalante
                    • Sep 2018
                    • 115
                    Code C-D012
                    That code was presented to me on a Bizhub C754e.
                    I solved it as follows.
                    First step: Format the hard drive in physical form.
                    Second step: Format logically. When it finishes making the logical format process, the panel indicates to turn off and on the equipment. I just paid. Third step: Load the firmware with the next version that the equipment currently had, which was K7 to K9 and problem solved. I hope this solution will help you a lot.
