C71HC Image Fault
  • inutelkamo
    • Jul 2011
    • 143
    C71HC Image Fault
    Good Day,
    Have you stumbled in this kind of print out?
    (Please see attached image)
    Its suppose to be Gray, not rainbow.. haha
    Look closely on vertical CMY area..
    All thoughts and suggestions are highly appreciated.
    PS.
    DRUM CMY - 5%
    Drum K - 98%
    Charging - CMYK - 5%
    Image Transfer Belt - 155/100 Page life
    1 and 2nd Transfers 155/100 Page life
    2nd Tranfer Lower 155/100 page life
    Developer all between 60%-70%
    Still waiting for Belt and Rollers to arrive.
  • lartis.aineias
    • 78
    Re: C71HC Image Fault
    Originally posted by inutelkamo
    Good Day,
    [ATTACH=CONFIG]49506[/ATTACH]
    [ATTACH=CONFIG]49507[/ATTACH]
    Classic drum bandings!!! Try to change the dot from 190 to 175 may help
    The other solution is to change the drum's
    Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
    • inutelkamo
      • Jul 2011
      • 143
      Thanks for the tips..
      Will Change the Dot to 175 on next visit..
      and ohh, Drum is still fresh.. At 5%.. Except the the Black Drum.
      • lartis.aineias
        • 78
        I usually have this problem with clients who print few copies.
        The drums sit on the blades!
        • tulintron
          • Jul 2014
          • 668
          You can print the separate colors and measure the distance between the marks. I would shoot drums or developer units.
          • inutelkamo
            • Jul 2011
            • 143
            Nice Nice.. Thank You..
            Will review the process unit on next visit.
            Maybe this,
            This drum was fresh from the box, but I cancel the installation of this drum unit when i saw this.
            Maybe i didn't notice this on other colors during drum replacement.
            Still waiting for the shipment of new DU Units for testing..
            Have a good day..
            • inutelkamo
              • Jul 2011
              • 143
              Copy!
              Will work on this when new DU is already available.
              Thanks a lot.
                • 23009
                Try these originals:
                • inutelkamo
                  • Jul 2011
                  • 143
                  Nice, thanks!
                  Will Update soon..
