Bizhub C220 fax problems
  • Runfun
    • Jun 2021
    • 4
    Hey Guys we have a problem with our Bizhub C220.
    A long time the printer was working really good without any problems.
    But last week we lost some data.
    Now we have the problem that we can not send out a fax.
    We can receive it but not sending.
    The problem is that the printer want always send the fax by mail.
    Even if we choose normal fax, we can input the number, but the we receive this error.
    You can see on the picture the printer always want send the fax by mail.IMG_6771.jpg
    I think some settings are not correct.
    If somebody have a idea I really appreciate it.
    Greetings
    Runfun
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub C220 fax problems
    thats looks like someone is typing a fax number as if its a email
    • Gift
      • Mar 2011
      • 2459
      I agree, these jobs are markes as "e-mail" in the job log instead of fax. What kind of data has been lost, did the MFP crashed?
      In that case the Fax option might have become disabled in service mode and needs to be enabled again. You also might take a look in
      user/admin settings if you can see the usual fax-related buttons/settings. Still odd that you can receive though. In case everything looks OK:
      What happens if you dial manually after pushing that "(un)hook line" button - I think that button looks like a telephone.
      • Runfun
        • Jun 2021
        • 4
        No we only type a number insider for example +497119271467
        I think its a interface problem ... where i can tell the printer its a fax ... are there some settings send fax as email or something like that ?
        • rrrohan
          • Sep 2011
          • 1977
          fax as email?
          • Gift
            • Mar 2011
            • 2459
            IP fax is "kind of" based on e-mail but I can't imagine that this has been accidentally activated.
            • rrrohan
              • Sep 2011
              • 1977
              yeah i honestly think the fault is users selecting email on direct input then typing a fax number
              • Gift
                • Mar 2011
                • 2459
                might be but on the other hand hard to imagine if they worked with the MFP before for a long time. Well I think we gave enough hints to follow..
                • Runfun
                  • Jun 2021
                  • 4
                  Can not be we choose fax sending ..
                  It's German but I think you can read it or see it :-)
                  The question is where in the printer setup is the interface ...
                  • Gift
                    • Mar 2011
                    • 2459
                    [ATTACH=CONFIG]49516[/ATTACH]
                    Looks fine indeed. What about manual dialing - can you hear the line in this mode? Have you tried disable/enable the FK via SP?
                    • emujo2
                      • Mar 2017
                      • 1579
                      I think the problem will not be understood or resolved until you can explain the "we lost some data" comment. Your device is trying to send fax by email. If it was not doing this before then you really need to define what happened, and what you did to recover from the problem. E
                      • Runfun
                        • Jun 2021
                        • 4
                        Yeah the problem .. i know normally if I switch to fax there is a button where I can check the line.
                        Unfortunately that button is missing.
                        But the line is ok .. because I can receive a fax.
                        What do you mean with "Have you tried disable/enable the FK via SP?"
                        Greetings Runfun
                        • emujo2
                          • Mar 2017
                          • 1579
                          I have seen 2 reasons that the off hook button went away..Open API from solution did not support it, and Confirm Address (TX) function is enabled. E
                          • Gift
                            • Mar 2011
                            • 2459
                            Greetings Runfun
                            SP = service program/mode, FK = fax kit
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4789
                              Make sure the fax target country is correct in service mode.
