Konica Minolta C1060 - conflicting printer settings
  • Corbane11
    • Jun 2021
    • 2
    [Misc] Konica Minolta C1060 - conflicting printer settings
    As of recently, I run a Konica Minolta c1060, haven't posted on here before.
    I'm trying to print a portrait double sided brochure on regular copy paper. As far as I can tell the paper settings are okay. The issue I'm having is I can make it print portrait just fine but it won't be double sided, alternatively I can print double sided but it comes out in landscape. In the Layout tab, if I keep it on Normal I can override it to portrait every time, however there is no setting in Normal to achieve double sided printing. If I switch to Gangup, I get the double sided printing I want, except now it comes out landscape when I want portrait and there's no setting to fix it. Basically, I can get one but not both at the same time, leading me here.
    I could print one side and then the other, but since I need a lot of copies it would be tedious.
    If anyone has a solution to my problem I would greatly appreciate it.
  • Synthohol
    Certified Konica Expert
    • 5827
    Re: Konica Minolta C1060 - conflicting printer settings
    With or without a fiery?
    • Corbane11
      • Jun 2021
      • 2
      With Fiery Command, Yes
      • Synthohol
        • 5827
        I would just import the job using CWS and set the properties in that to duplex.
        It sounds stupid but if you set 2 sided in the APPLICATION window AND 2 sided in fiery properties they cancel each other out.
        Paper/job/finishing preferences are always to be set in the fiery preferences not the application print window.
