How to set https from computer to copier interface?
  • adecanmin
    • Oct 2010
    • 319
    Gentlemen.
    How is that done? I installed a self signed certificate. Enabled SSL and made some other setting changes needed. Still no https.
    • 30409
    Re: How to set https from computer to copier interface?
    Security tab Enable SSL
    • Select a mode from the [Mode Using SSL/TLS] drop-down list. ...
    • Select an encryption strength from the [Encryption Strength] drop-down list.
    • Select the checkbox of the SSL version to be used.
    • Click [OK]. ...
    • Click [OK] on the setting complete screen.
    You can access http or https by ipaddress
    • adecanmin
      • Oct 2010
      • 319
      • Click [OK]. ...
      It is enabled.
      Under protocol settings I see nothing for https. Not sure if it matters. I tried two different Konicas and could not get https to work. Is there a soft switch I need to change for HTTPS? I wouldn't think so because everything seems to be done under administrator. I followed the user guides. Looked at various videos. Everything is set up but still no go.
        • 30409
        Originally posted by adecanmin
        It is enabled.
        Can you access through http ?
        • adecanmin
          • Oct 2010
          • 319
          yes.
          It has the warning in red. SSL is not set-up Please set up SSL after admin logins to secure safety of the information. If I use https with the ip I can't get in. There has to be someone that has setup HTTPS successfully on the interface. Especially in an enterprise company where the I.T. administrator would want HTTPS for communicating with the copier.
            • 30409
            Try a different web browser
            don't worry about not an issue
            • mojorolla
              The Wolf
              • 2630
              Did you reboot the machine after installing the new cert ?
              This is required on an current KM boxes
              • emujo2
                • Mar 2017
                • 1579
                try from scratch again..delete the factory installed SSL cert. Create a new cert based on 2048/256, go into SSL and enable both user and admin, select all 4 radio buttons. You browser should pop up the new "warning". E
                • adecanmin
                  • Oct 2010
                  • 319
                  Thanks I'll give it a try and post back my results
