Konica Minolta Bizhub C308 error code C-3725 not removing
  • dsdahanayake
    • Jul 2021
    • 2
    In my bizhub C308 C-3725 error code came and plug the fusing unit to another bizhub C308 printer and it worked perfectly and then technician advised the issue was with Power supply board and it also plug to a working C308 machine and the Power supply board also working fine. However, when it plugs again to my C308 machine still the error code existing. I have done the error code reset using rest button and using service mode. Still the error display, how do I resolve this issue? Which unit to check next? Appreciate any advice
  • blinxwap
    • Jun 2020
    • 80
    Re: Konica Minolta Bizhub C308 error code C-3725 not removing
    Try system error clear on service mode
    Sent from my Hisense U40 using Tapatalk
    • Synthohol
      Certified Konica Expert
      • 5820
      Error
      C3725 occurs during copying/printing or at idle.
      Root Cause
      Failed MFP Board (MFPB)
      Workaround/Fix
      Prior to board replacement, perform the following check.
      1. Select Counter
      2. Select Display Keypad
      3. Press Stop 00. Stop 01
      4. If applicable input CE password 9272 4 times (Default)
      5. Select State Confirmation
      6. Select Self-diagnostic
      7. Select Check All
      8. Press Start
      9. Repeat steps 1-8 3 more times
      10. If result is NG, replace the MFPB based on model listed below.
      • bizhub C258/C308/C368 (p/n A7PUH02123)
      • bizhub C458 (p/n A79MH02102)
      • bizhub C558/C658 (p/n A79JH02102)
      Notes:
      1. Prior to loading firmware under Machine Type Select: Verify Machine and Type
      2. It is necessary to update the firmware to support the new MFPB
      Technical Notes
      Please review the MFPB replacements procedure in Service Manual and be careful when transferring EEPROMS that they do not become damaged and they get installed in the same location on the replacement MFPB
      • dsdahanayake
        • Jul 2021
        • 2
        Originally posted by Synthohol
        Error
        Root Cause
        Workaround/Fix
        1. Select Counter
        7. Select Check All
        8. Press Start
        Notes:
        Technical Notes
        Much appreciated your guided workaround .
        I have done the Self-diagnostic only 1 time. Will try again with 3 attempt.
        If it will still exist the error, can I re install the firmware with existing MFP Board to resolve the issue?
        • Synthohol
          • 5820
          • tsbservice
            Field tech
            • 8007
            I guess it won't work(firmware update) but you have nothing to lose so why not.
