Error code C-D012 on KONICA C754e
  • konixcavn
    • Jul 2021
    • 3
    [Error Code] Error code C-D012 on KONICA C754e
    Hello all of you!
    I'm Vietnamese and new to the forum. I am having problem with konica C754e. error CD012. Hope everybody help please. Thanks very much!
  • lartis.aineias
    • 78
    Re: Error code C-D012 on KONICA C754e
    Hi
    I don't have the service manual c754
    But in the service manual of c364 is probably the hhd problem.
    Στάλθηκε από το AC2003 μου χρησιμοποιώντας Tapatalk
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      Format HDD and if that don't work replace it.
      You can still get into service mode to format HDD even with the trouble code on display, just have to wait a few minutes.
      • CryptKeeper
        • Jan 2021
        • 1
        I would try reinstalling/updating the firmware, especially if you just wiped the drive and SSD. In my experience, after the wipe, a 654/654 will throw a D012 error, and reinstalling the firmware, will fix this. The drive will also require a logical format after a wipe.
        • Walterj
          KONICA MINOLTA
          • Jun 2017
          • 89
          Originally posted by konixcavn
          Hello all of you!
          Good day:
          If you want a specific FW Base or FW Special, or any resolution of any error code that your machine may emit, you can only write to my email walvaradocruz@gmail.com
          Regards.
