i series with mpsmonitor software
  • Massimiliano
    • Oct 2019
    • 48
    Good morning everyone!
    I need help with the i series.
    with the "mpsmonitor" consumable management software, I only see the status of the toners.
    Can anyone tell me how to activate the display of the drum, developer, fuser and belt on the machine?
    Thank you
  • rrrohan
    • Sep 2011
    • 1977
    are you using snmp v2 or v3?
    that looks exactly the same has HP SDS
    • Massimiliano
      • Oct 2019
      • 48
      the machine is set up like this: Impostaz. SNMP
      SNMP
      SNMP v1/v2c(IP)
      SNMP v3(IP)
      I had the same problem with the c458 and I solved it with this setting:?
      Swich No. 230
      HEX 00
      but on i series machines it doesn't work
      thank's
      • tsbservice
        Field tech
        • 8048
        SNMP
        SNMP v1/v2c(IP)
        SNMP v3(IP)
        Swich No. 230
        HEX 00
        thank's
        Try it with HEX 08
        • Thib
          • May 2017
          • 35
          Not sure about the software side, but to get anything besides toner to show up on the machine side consumables it's:
          SW 227
          Hex 00
          • Synthohol
            Certified Konica Expert
            • 5888
            ^^^^^^^^yup^^^^^^^
            • Massimiliano
              • Oct 2019
              • 48
              SW 227
              Hex 00
              hi, thank you very much but I have already activated this switch No.
              • Massimiliano
                • Oct 2019
                • 48
                Try it with HEX 08
                HI,
                because you advise me to modify switch No. HEX 08,
                on the 8 series I had to set HEX00
                in the i series I noticed that by default switch No. 230 is set to HEX 48.. why?
                Thank you?
                • tsbservice
                  Field tech
                  • 8048
                  HI,
                  Thank you
                  This is different model.
                  • plus-COPY
                    • Aug 2023
                    • 34
                    Does it really look like this,
                    that in MPSmonitor you can't see the data of materials in the "i" series? Has it always been like this?
                    • Massimiliano
                      • Oct 2019
                      • 48
                      Good morning,
                      on the seir i leaving HEX 48 does not send data, I will try to set it to 08 as recommended by tsbservice and I will update you.
                      Thank you
                      • Massimiliano
                        • Oct 2019
                        • 48
                        Good evening,
                        For information I solved it by setting the machine like this:
                        Switch 227 --> HEX 00
                        Switch 230 -->HEX 40
                        Thank you all
