Konica 308E Print Quality Problem
  • ferro10
    • Jun 2015
    • 109
    #16
    Originally posted by elmaligno
    None, it works OK, and contrary to the manufacturer's claims, it lasts much longer.
    Ok thanks for the suggestion
    • tsbservice
      Field tech
      • 7970
      #17
      I will try. How many prints typically you get from dr313k in 8e series?
      • elmaligno
        Expert technician KM
        • Oct 2009
        • 302
        #18
        the case is that the drum of that model should last about 225,000 prints, depending on the speed of the machine, but the cleaning system incorporates, which is the "modern" version with the yellow brush makes it fail much earlier, even I have changed them with 40,000 prints or less, without the machine had any additional problem. The drum of the c308 lasts about 120.000-150,000 impressions, which is what it has to last, but considering that it costs almost half and that the reality of duration is that .... I think there is no doubt, but you can try.
        They also released a few years ago a special drum for the C308 series (DR-315K) that cost twice as much and should last twice as long, it only worked with firmware version G00-V1 onwards and was physically like the one in the BH308e, I bought some and it gave me the same bad result.
        Field technician since 1994
