Konica 308E Print Quality Problem
  • ferro10
    • Jun 2015
    • 117
    [Misc] Konica 308E Print Quality Problem
    Hi everyone
    The problem is what he sees attached.
    This problem only presents itself after a rest phase and after 2 pages it is completely disappeared.
    It is not the first time that I have this problem on this specific printer. The other time I had replaced Drum and Developer but the problem came up after 90,000 pages.
    I would like to understand if there is a bulletin or if other users have had the same problem
    thank you all
  • Toxic
    • 698
    Seen this many times on this series and every time drum was cause.
    Times when drums on 4 series lasted over 200k is now over with new pcr method nowadays.
    • kingarthur
      • 1385
      I've got many 8 series devices with all drums over 200% - one is in an architects with lots of colour copying. i'll only fit genuine KM drums though
      • ferro10
        • Jun 2015
        • 117
        I also have 8 series in color with duration beyond the declared life.
        I am encountering a problem with the 308E/368E series. New and original drums and developers were installed in 2/2023, but after just 90,000 pages, the same problem persists
        • copyman
          Owner / Technician
          • Sep 2005
          • 4755
          I agree with toxic that the 8 series drums suck. You are lucky to get 1/2 the life out of OEM drums in lower volume accounts. PCR's have no place in faster copiers. PCR's are ok for small printers but not copiers.
          • ferro10
            • Jun 2015
            • 117
            Have you found a solution to the problem? Is Konica aware of this drum duration issue?
            • tsbservice
              Field tech
              • 8048
              Drums and fusers for this series 8e are very bad. Drum can show signs on prints at 50% and fusers give up early too.
              • kingarthur
                • 1385
                What is the rotation time for the "failed" drum - as KM measure the drums in rotation time "M" as well as prints - it's possible for the drum to have done the required amount of rotations, even though it hasn't carried out the prints
                • ferro10
                  • Jun 2015
                  • 117
                  The number of rotations is 4921M
                  • Woxner
                    • Jul 2011
                    • 852
                    I have had this many times. It's always the drum
                    • elmaligno
                      Expert technician KM
                      • Oct 2009
                      • 302
                      Hi everyone
                      thank you all
                      The solution is very simple, the 8e series drum is crap, use the black c308 drum, which will fit perfectly, is cheaper and will last twice as long.
                      Field technician since 1994
                      • ferro10
                        • Jun 2015
                        • 117
                        Is there any physical changes to make? Is the chip to change?
                        • tsbservice
                          Field tech
                          • 8048
                          I didn't tried DR313K in place of DR314K but see attached.
                          • elmaligno
                            • Oct 2009
                            • 302
                            None, it works OK, and contrary to the manufacturer's claims, it lasts much longer.
                            • tsbservice
                              Field tech
                              • 8048
                              Good to know, Thanks for the hint.
