C458 customer wants a wired connection and wireless connection for printing
  • adecanmin
    • Oct 2010
    • 321
    Gentlemen
    Customer wants the wired network and wireless to be separated for printing. I searched for a wireless bridge that will work with the usb port on the copier. Could not find one. Is there another way?
    • 30477
    Re: C458 customer wants a wired connection and wireless connection for printing
    Just add a access point or have them get a new router that supports wireless.
    • adecanmin
      • Oct 2010
      • 321
      That's what I figured. thanks.
      • rrrohan
        • Sep 2011
        • 1977
        So they want WiFi Direct Printing? Most building sites like this option so sub contractors can easily print without needing the actual wifi code
        Sent from my Pixel 4 XL using Tapatalk
        • adecanmin
          • Oct 2010
          • 321
          It won't be that convenient. They will need the Wi-Fi password. It is a therapy place . They want the therapists on one network and the office staff on the other. More so to reduce broadcast traffic.
          • rrrohan
            • Sep 2011
            • 1977
            VLAN?
              • 16472
              So, they'll only have 2 Wireless SSID's? And how many users will be on each wireless network?
              I agree with rthonpm about using VLANs but are there really enough users for broadcast traffic to be a concern?
              • adecanmin
                • Oct 2010
                • 321
                Not big enough to be a concern. 25 max users on one and maybe 5 or so on the other. I've never set up the vlan function on the c458. I not involved with the network. They are handling it. I'm just offering some advise.
                  • 16472
                  VLANS are set up @ the switch and it virtually creates separate networks thus limiting broadcast traffic to the individual VLAN. It's gonna be the most simple way to accomplish what you're trying to do. Otherwise, you'd have to install another router to contain broadcast traffic.
                    • 30477
                    • adecanmin
                      • Oct 2010
                      • 321
                      Ok
                      • emujo2
                        • Mar 2017
                        • 1579
                        You could simply add the wireless kit (UK 212 I think). In service mode you would tell the machine to use both wired and wireless, you would connect to a broadcasting wireless or set the wireless option to be it's own SSD, this would limit the amount of users that could connect to it, but works pretty well. Then the wired portion provides connectivity for the masses. E
                        • adecanmin
                          • Oct 2010
                          • 321
                          Ok. I'll see if I can find a used one. The C458 has been out a while.
