Bizhub C224e 66-05 code
  • RandyW
    • Jan 2013
    • 213
    Had numbers 22 & 25 in the little circles.
    DF701 I think.
    blew some canned air on and around the Document Reading Sensor (A143PP7900 part number?)...was ok for a short time, account called back saying it said jam again.
  • rrrohan
    • Sep 2011
    • 1977
    also make sure the black part it reflects off when paper isnt in the path is clean of paper dust
    • copyman
      Owner / Technician
      • Sep 2005
      • 4712
      What about the feed rollers? If DF701 did you open 2nd side CCD unit door on underside of ADF and blow out with air?
      • tsbservice
        Field tech
        • 8019
        +1 I even use black marker sometimes on pad/felt.
        • RandyW
          • Jan 2013
          • 213
          Ended up replacing A143PP7900 & A108M50100 (hmmm I forget which interrupter it was...maybe an exit)
