C360 Paper Passage Test Outputting from Tray 1
  • ArrowGB
    • Apr 2021
    • 12
    My apologies if there is already a thread about this, but I'm unable to find it if there is one...
    When running paper passage through CE mode on a C360 of mine, the sheets are depositing in tray 1 of the finisher (top tray) rather than tray 2 where they should be depositing. I've had this happen once before and cannot remember what I did to fix it. The output settings in admin mode do not include any settings for paper passage specifically. Anybody know where I can find the setting for this? Thank you in advance.
  • K-3
    service technician
    • Feb 2018
    • 51
    Re: C360 Paper Passage Test Outputting from Tray 1
    i did not see anything specific in paper path testing either. did you try in the output settings to change printing to go to tray 2 on finisher.
    • Synthohol
      Certified Konica Expert
      • 5905
      You are in service mode, paper will always come out on top.
      It's a paper passage test not operate finishing capability test.
