Bizhub C224e Card Reader
  • smash
    • Aug 2021
    • 7
    Hi all,
    Do you know if it is possible to make a generic card reader to work with the Bizhub C224e printer?
    If not which card readers are currently available?
    Thank you very much.
  • emujo2
    • Mar 2017
    • 1579
    Re: Bizhub C224e Card Reader
    The C224e can use the AU 201H, 205H, barcode, magstripe or RFIDEAS (AK0)...If you could get your generic card to work like a AU-205 in KBW mode if you can find the USB/VID codes for it..There is a place in the authentication settings that used these codes for the older machines (new LDDs have this already programmed in). What is a "generic" reader?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4657
      Originally posted by smash
      Hi all,
      I have several removed from the C224e & other "4" series. Contact me if you want to buy cheap!
      • avecosat
        • Jun 2012
        • 305
        For this model I always use YSOFT Reader v2 Multireader LF + HF
        • smash
          • Aug 2021
          • 7
          Thank you very much for your replay.
          Generic, I mean a cheap card reader from Amazon, our model is KKMOON 14443A which reads MIfare Classic 1K. To give it a try i should look if there are any avaialble dirvers/codes for my device, right?
          • avecosat
            • Jun 2012
            • 305
            You need to install a driver and enable card mode
            • smash
              • Aug 2021
              • 7
              Ok, thank you.
              • emujo2
                • Mar 2017
                • 1579
                Still need to know if your generic card is a CCID reader or keyboard wedge. There are no KM LDD drivers for this particular reader.
                • smash
                  • Aug 2021
                  • 7
                  I will search compatible card readers AU 201H etc. Thank you for your help.
                  • smash
                    • Aug 2021
                    • 7
                    Hi again,
                    I want to enable the autenticatin method device. When I go Adminisrator Settings -> User Authentication -> Authenticathion Device Setting is missing.
                    Am I skipping a previous step? I have access to Service Mode.
                    • avecosat
                      • Jun 2012
                      • 305
                      In service mode stop 9 , management function choice , Authentication device2 , Auth mode - card
                      • smash
                        • Aug 2021
                        • 7
                        Done, thank you avecosat
                        • smash
                          • Aug 2021
                          • 7
                          Hi i am thinking buying a new card reader OMNIKEY 5022 which is the same brand as the au-201H. Do you know if the driver for au-201H will be compatible?
                          • emujo2
                            • Mar 2017
                            • 1579
                            Au-201H is the Omnikey 5325, so no, it won't work.
