Konica Minolta B4052, toner detection error
  • byronf
    Senior Member
    • Sep 2017
    • 109
    [Error Code] Konica Minolta B4052, toner detection error
    Konica Minolta B4052, set up toner has been depleted after installing new toner a toner detection error is displayed.
    The machine was running well before toner ran out. I put in new 2 other oem toners and imaging unit. msg will not go away. it only drives for a few seconds when you close the door. in the service mode several items have been greyed out. level history, load check, gradation, stabilizer. Marketing area is correct I even initialized and reset up the machine my last resort was updating the firmware and still I have had no luck.
  • Albonline
    • Sep 2008
    • 1144
    Re: Konica Minolta B4052, toner detection error
    examine the electrical contact points inside the printer for the toner and drum units.
    • byronf
      Senior Member
      • Sep 2017
      • 109
      Hi Albonlibe,
      I swopped the chips of the depleted toner and the first replacement toner. The errors are swopped it seems like we have the incorrect region toner.
      I was hoping to get a work around solution.
      • Albonline
        • Sep 2008
        • 1144
        Originally posted by byronf
        Hi Albonlibe,
        not on this model.
        • pickle8486
          • Aug 2013
          • 26
          What was done to fix this issue? I am experiencing the same thing now. We have tnp63 Toner but the machine had tnp64 , which is now not available. One is UAR and the other Standard. Machine is down and I have switched UAR drum and standard drums both new to see if that fixed the issue but it didnt.
